RandomNASChap's avatar
Jun 10, 2017
RN316 works with CyberPower Value 1000EI
Just a note for anyone searching that I can confirm the ReadyNAS model RN316 six-bay running firmware 6.7.4 works properly with the CyberPower Value 1000EI.
Specifically
- the CyberPower Value 1000EI-AU (Australian version, 2x AU plug receptacles, USB, network passthrough)
- this UPS cost about AU$130 at time of writing
- some time was required and a couple of restarts of the NAS to have the RN316 automatically 'see' the UPS, but eventuall it worked
- at this stage the USB cable only works when plugged in to the NAS's front USB2 port, not when plugged into either of the back USB3 ports
I tested the NAS was receiving the correct info from the UPS, and that the NAS was correctly responding to the information from the UPS, by using a method described by other users in this forum (can't find the post to properly give them credit, sorry).
1. Plug UPS into wall power outlet
2. Plug NAS into seperate wall power outlet
3. Plug UPS USB into NAS USB so they can communicate
4. Plug a lamp into the UPS power
5. Switch everything on
6. Ensure NAS sees the UPS
7. Set NAS to shutdown at your preferred % of battery (I just want a nice proper shutdown if the building pwer goes out, so I set my RN316 to power down at 90% battery)
8. Check that the NAS is NOT plugged into the UPS power!
9. Switch off wall power to the UPS.
10. What should happen is that the UPS loses mains power and goes to battery power, sends a message by USB to the NAS, and eventually the NAS shuts down gracefully, whilst the lamp stays lit on battery until the batteries run out.
11. This method doesn't risk a hard shutdown of the NAS (it's plugged into the wall), but checks that the UPS and NAS are talking to each other, and that your NAS settings do what you think they should do.
Thanks to the other users who actually came up with this test, you're the heroes we needed...
Cheers.
1 Reply
  • Specific links in case they matter:
    https://www.cyberpower.com/au/en/product/series/Backup%20UPS%20Systems/Value%20SOHO
    https://www.cyberpower.com/au/en/product/sku/Value1000EI
    CyberPower Value1000EI offers home and office users a reliable battery backup and safeguards office PCs, network communication equipment, and other electronic devices from surges, spikes, brownouts and other power incidents. Designed with GreenPower UPS™ Technology to improve operating efficiency and to minimize energy consumption, users can enjoy significant energy cost savings over conventional UPS systems. The UPS provides Automatic Voltage Regulation (AVR) to maintain safe voltage for connected equipment. The featured data line protection protects phones, networks, and other communication equipment against surge/spikes and other power irregularities.
    FEATURES
    • Line-interactive UPS Topology
    • Energy Saving Technology
    • Simulated Sine Wave Output
    • Automatic Voltage Regulation (AVR)
    • Surge and Spike Protection
    • Phone/ Fax/ Modem/ DSL/ Network Protection
    • PowerPanel® Management Software
    • Tower Form Factor
    GENERAL
    UPS Topology Line-interactive
    Energy Saving Technology GreenPower UPS™ Bypass Technology
    INPUT
    Nominal Input Voltage (Vac) 230 ± 10%
    Input Voltage Range (Vac) 170 ~ 290
    Input Frequency (Hz) 50 ± 5 60 ± 5
    Input Frequency Detection Auto-sensing
    Rated Input Current (A) 4.55
    Input Connector Type IEC C14
    Detachable Power Cord Plug Type AU
    Power Cord Length (ft.) 6
    Power Cord Length (m.) 1.8
    OUTPUT
    Capacity (VA) 1000
    Capacity (Watts) 550
    On Battery Waveform Simulated Sine Wave
    On Battery Voltage(s) (Vac) 230 ± 10%
    On Battery Frequency (Hz) 50 ± 1% 60 ± 1%
    Automatic Voltage Regulation (AVR) Single Boost, Single Buck
    Overload Protection Fuse
    Outlet(s) - Total 2
    Outlet Type AU x 2
    Outlet(s) - Battery & Surge Protected 2
    Typical Transfer Time (ms) 4
    BATTERY
    Runtime at Half Load (min) 7
    Runtime at Full Load (min) 1
    Typical Recharge Time (Hours) 8
    Start On Battery Yes
    User Replaceable No
    Battery Type Sealed Lead-acid
    SURGE PROTECTION & FILTERING
    Surge Suppression (Joules) 125
    EMI/RFI Filtration Yes
    Phone/Network Protection RJ11/RJ45 (Combo) 1-in, 1-out
    MANAGEMENT & COMMUNICATIONS
    LED Indicators Power On , Line Mode , Battery Mode , Low Battery
    HID Compliant USB Port(s) 1
    Serial Port RS232
    Audible Alarms Battery Mode , Low Battery , Overload , UPS Fault
    Power Management Software PowerPanel® Personal Edition
    PHYSICAL
    Form Factor Tower
    Enclosure Construction Plastic
    Color Black
    PHYSICAL SIZE - UPS MODULE
    Dimensions (WxHxD) (in.) 3.937 x 5.512 x 11.811
    Dimensions (WxHxD) (mm.) 100 x 140 x 300
    Weight (lbs.) 12.125
    Weight (kg.) 5.5
    ENVIRONMENTAL
    Operating Temperature (°F) 32 ~ 104
    Operating Temperature (°C) 0 ~ 40
    Operating Relative Humidity (Non-condensing) (%) 0 ~ 90
    Operating Elevation (feet/meters) 0-10,000 feet (0-3,000 meters)
    Storage Temperature (°F) -4 ~ 122
    Storage Temperature (°C) -20 ~ 50
    Storage Relative Humidity (Non-condensing) (%) 0 ~ 90
    Storage Elevation (feet/meters) 0-10,000 feet (0-3,000 meters)
    Online Thermal Dissipation (BTU/hr) 109
    Audible Noise at 1.5M from Surface of Unit (dBA) 40
    CERTIFICATIONS
    Certifications CE , C-Tick , EAC
    RoHS Yes
    WARRANTY
    Product Warranty Period (Year)2
    Battery Warranty Period (Year)2
ProSupport for Business
