RandomNASChap
Jun 10, 2017Aspirant
RN316 works with CyberPower Value 1000EI
Just a note for anyone searching that I can confirm the ReadyNAS model RN316 six-bay running firmware 6.7.4 works properly with the CyberPower Value 1000EI.
Specifically
- the CyberPower Value 1000EI-AU (Australian version, 2x AU plug receptacles, USB, network passthrough)
- this UPS cost about AU$130 at time of writing
- some time was required and a couple of restarts of the NAS to have the RN316 automatically 'see' the UPS, but eventuall it worked
- at this stage the USB cable only works when plugged in to the NAS's front USB2 port, not when plugged into either of the back USB3 ports
I tested the NAS was receiving the correct info from the UPS, and that the NAS was correctly responding to the information from the UPS, by using a method described by other users in this forum (can't find the post to properly give them credit, sorry).
1. Plug UPS into wall power outlet
2. Plug NAS into seperate wall power outlet
3. Plug UPS USB into NAS USB so they can communicate
4. Plug a lamp into the UPS power
5. Switch everything on
6. Ensure NAS sees the UPS
7. Set NAS to shutdown at your preferred % of battery (I just want a nice proper shutdown if the building pwer goes out, so I set my RN316 to power down at 90% battery)
8. Check that the NAS is NOT plugged into the UPS power!
9. Switch off wall power to the UPS.
10. What should happen is that the UPS loses mains power and goes to battery power, sends a message by USB to the NAS, and eventually the NAS shuts down gracefully, whilst the lamp stays lit on battery until the batteries run out.
11. This method doesn't risk a hard shutdown of the NAS (it's plugged into the wall), but checks that the UPS and NAS are talking to each other, and that your NAS settings do what you think they should do.
Thanks to the other users who actually came up with this test, you're the heroes we needed...
Cheers.
1 Reply
- RandomNASChapAspirant
Specific links in case they matter:
https://www.cyberpower.com/au/en/product/series/Backup%20UPS%20Systems/Value%20SOHO
https://www.cyberpower.com/au/en/product/sku/Value1000EI
CyberPower Value1000EI offers home and office users a reliable battery backup and safeguards office PCs, network communication equipment, and other electronic devices from surges, spikes, brownouts and other power incidents. Designed with GreenPower UPS™ Technology to improve operating efficiency and to minimize energy consumption, users can enjoy significant energy cost savings over conventional UPS systems. The UPS provides Automatic Voltage Regulation (AVR) to maintain safe voltage for connected equipment. The featured data line protection protects phones, networks, and other communication equipment against surge/spikes and other power irregularities.
FEATURES
- Line-interactive UPS Topology
- Energy Saving Technology
- Simulated Sine Wave Output
- Automatic Voltage Regulation (AVR)
- Surge and Spike Protection
- Phone/ Fax/ Modem/ DSL/ Network Protection
- PowerPanel® Management Software
- Tower Form Factor
GENERALUPS Topology Line-interactiveEnergy Saving Technology GreenPower UPS™ Bypass TechnologyINPUTNominal Input Voltage (Vac) 230 ± 10%Input Voltage Range (Vac) 170 ~ 290Input Frequency (Hz) 50 ± 5 60 ± 5Input Frequency Detection Auto-sensingRated Input Current (A) 4.55Input Connector Type IEC C14Detachable Power Cord Plug Type AUPower Cord Length (ft.) 6Power Cord Length (m.) 1.8OUTPUTCapacity (VA) 1000Capacity (Watts) 550On Battery Waveform Simulated Sine WaveOn Battery Voltage(s) (Vac) 230 ± 10%On Battery Frequency (Hz) 50 ± 1% 60 ± 1%Automatic Voltage Regulation (AVR) Single Boost, Single BuckOverload Protection FuseOutlet(s) - Total 2Outlet Type AU x 2Outlet(s) - Battery & Surge Protected 2Typical Transfer Time (ms) 4BATTERYRuntime at Half Load (min) 7Runtime at Full Load (min) 1Typical Recharge Time (Hours) 8Start On Battery YesUser Replaceable NoBattery Type Sealed Lead-acidSURGE PROTECTION & FILTERINGSurge Suppression (Joules) 125EMI/RFI Filtration YesPhone/Network Protection RJ11/RJ45 (Combo) 1-in, 1-outMANAGEMENT & COMMUNICATIONSLED Indicators Power On , Line Mode , Battery Mode , Low BatteryHID Compliant USB Port(s) 1Serial Port RS232Audible Alarms Battery Mode , Low Battery , Overload , UPS FaultPower Management Software PowerPanel® Personal EditionPHYSICALForm Factor TowerEnclosure Construction PlasticColor BlackPHYSICAL SIZE - UPS MODULEDimensions (WxHxD) (in.) 3.937 x 5.512 x 11.811Dimensions (WxHxD) (mm.) 100 x 140 x 300Weight (lbs.) 12.125Weight (kg.) 5.5ENVIRONMENTALOperating Temperature (°F) 32 ~ 104Operating Temperature (°C) 0 ~ 40Operating Relative Humidity (Non-condensing) (%) 0 ~ 90Operating Elevation (feet/meters) 0-10,000 feet (0-3,000 meters)Storage Temperature (°F) -4 ~ 122Storage Temperature (°C) -20 ~ 50Storage Relative Humidity (Non-condensing) (%) 0 ~ 90Storage Elevation (feet/meters) 0-10,000 feet (0-3,000 meters)Online Thermal Dissipation (BTU/hr) 109Audible Noise at 1.5M from Surface of Unit (dBA) 40CERTIFICATIONSCertifications CE , C-Tick , EACRoHS YesWARRANTYProduct Warranty Period (Year)2Battery Warranty Period (Year)2
