CornHead764's avatar
CornHead764
RN3220 No OS
Hello,   I have an RN3220 that was completely wiped, all disks, and even the internal satadom were all wiped. The NAS (obviously) no longer boots, and I can't seem to figure out how to reload the f...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Apr 12, 2017
    I've sent you a few images you can try. If the SATADOM is at least 256MB I'd use the larger one. I'm not sure how large it is.
    Whilst not strictly accurate we do tend to refer to the device the firmware is located on as the flash. It's installed from there onto the disks, but it's still used for early part of the boot process after handover from the BIOS/UEFI.
ProSupport for Business
