Zishy
Apr 24, 2018Aspirant
RN4220S SataDOM/OS
Hello there, i recently purchased a RN4220S off ebay and the satadom module is missing. i already own a RN3220 and i wanted to move over to 10gbe for the home network. how would i go about installing...
mdgm-ntgr
Apr 24, 2018NETGEAR Employee Retired
Buying second hand is risky: there’s no warranty or support for second hand purchases.
The SATA DOM would need the same things on it that’s on the one in the RN3220. So you could dd an image of the flash.
If the specs are close to the stock one then USB Boot Recovery may work.
It’s rather unknown what state your RN4220 is in.
Some second hand sellers if they do any testing would consider lights coming on and fans spinning up as sufficient to conclude the unit’s in working condition which is very inadequate testing.
- ZishyApr 24, 2018Aspirant
would it be possible to just check the general health of the machine by just plugging in a monitor and some random ssd and installing debian on it ?
how would i go about putting the image on a random ssd and firing up the system?
