Johnbu
Mar 01, 2012Aspirant
RND2000 Duo v2
Hello, I'm thinking of buying a RND2000 Duo v2. But before I do, I need to confirm it will do my simple requirements. The PCs in workgroup/network are all running WinXP. Will it be able t...
mdgm-ntgr
Mar 01, 2012NETGEAR Employee Retired
Still may as well as use X-RAID2.
10 gig isn't much, but once you have the storage you may be surprised at how fast the amount of data you have grows.
