Johnbu
Mar 01, 2012Aspirant
RND2000 Duo v2
Hello, I'm thinking of buying a RND2000 Duo v2. But before I do, I need to confirm it will do my simple requirements. The PCs in workgroup/network are all running WinXP. Will it be able t...
mdgm-ntgr
Mar 01, 2012NETGEAR Employee Retired
The ReadyNAS does not support SSDs at this time. Please use disks from the http://www.readynas.com/hard_disk_hcl
The NAS alerts you if a disk fails. Be sure to setup and test email alerts.
