HansPirmo
Sep 11, 2017Aspirant
RND2000 Duov2 - OS reinstall - Password
I am now the owner of a ReadyNAS RND2000 Duo v2which gives me some problems. I have tried to boot the unit with only 1 drive inside using the boot description from your homepage using a clip and hold...
- Sep 14, 2017
HansPirmo wrote:
It is a little difficult, as the buttomlabel says:
NETGEAR ReadyNAS Duo RND2000 v2
That label is misleading. The v2 means "hardware revision 2 of the duo v1". If you have a v2, then the front panel would say duo v2.
The default password on the duo v1 is netgear1 not password.
The boot menu instructions are also different - here's a link to the hardware manual: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf The boot menu is described on pages 15-16.
HansPirmo
Sep 14, 2017Aspirant
Dear Marty_M
Thank you for your reply.
and the S/N label says:
RND2110-100ISS - TA 100-13393-01R32 - S/N 24M4197E00657
But I do my best (I am a young man at 72 years) and I will try to follow the instructions.
Kind regards
Hans Pirmo
Sep 14, 2017Guru - Experienced User
- HansPirmoSep 14, 2017Aspirant
Dear Marty_M
Thank you so much - Problem solved.
You have saved my day.
Kind regards
Hans Pirmo
