wrustAspirantSep 04, 2011RND2000 hardware problemIs WD2003FYYS - WD RE4 - 2 TB suitable for RND2000(ReadyNAS Duo)?
mdgm-ntgrNETGEAR Employee RetiredSep 04, 2011It is not on the HCLIt is recommended to only use disks on the compatibility list. Disks not on the compatibility list may/may not work.Welcome to the forum!
Related ContentRND2000 flashingC7500 Hardware Problem?RND2000 v2 accesso all'interfaccia amministratorereadynasduo RND2000 V2RND2000-V2 cannot reset to select factory default
NETGEAR Academy Boost your skills with the Netgear Academy - Get trained, certified and stay ahead with the latest Netgear technology! Join Us!
ProSupport for Business Comprehensive support plans for maximum network uptime and business peace of mind. Learn More
