wrust
Sep 04, 2011Aspirant
RND2000 hardware problem
Is WD2003FYYS - WD RE4 - 2 TB suitable for RND2000(ReadyNAS Duo)?
wrust
Anyone has tried to use WD2003FYYS - WD RE4 - 2 TB in RND2000 ?
I know it's not on HCL.
Thank you,mdgm.
mdgm wrote: It is not on the HCL
It is recommended to only use disks on the compatibility list. Disks not on the compatibility list may/may not work.
Welcome to the forum!
Thank you,mdgm.
