GennaroProx
Apr 12, 2024Tutor
RND2000 v2 accesso all'interfaccia amministratore
Salve a tutti, dopo qualche anno di non uso, ho ricollegato alla LAN il mio ReadyNAS Duo v2 ma mi risulta impossibile accedere alla interfaccia di amministrazione, quando ci provo Chrome mi restituis...
- Apr 12, 2024
GennaroProx wrote:
devo usare la procedura come se stessi installando un nuovo firmware?
No, it is installed as an add-on. See page 74 and following in the software manual:
Apr 12, 2024Guru - Experienced User
GennaroProx wrote:
"192.168.0.25 utilizza un protocollo non supportato.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH"
Use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting). Then you will be able to connect.
The underlying problem is a while back browsers began requiring TLS 1.2. And your old NAS doesn't support that protocol. Updating the firmware won't resolve the problem. We can give you other options, but first please confirm the model.
A Duo v2
- runs 5.3.x firmware
- says ReadyNAS Duo v2 on the front panel
The original Duo (called a v1 here)
- runs 4.1.x firmware
- says ReadyNAS Duo on the front panel
- often has other labels that include "v2".
GennaroProx
Apr 12, 2024Tutor
- è la versione del mio NAS
- StephenBApr 12, 2024Guru - Experienced User
So it is a v2.
After you regain access with FireFox, you can install this add-on to give you TLS 1.2 support.
- GennaroProxApr 12, 2024Tutor
come si installa questo file? devo usare la procedura come se stessi installando un nuovo firmware?
