mike_wilson
Oct 17, 2025Aspirant
RND2000-V2 cannot reset to select factory default
i have two RND2000-v2 that both are causing the same problem. Let me first say that i do not have the current password so i have to do a boot and default to factory settings. If i power up, with...
- Oct 23, 2025
thanks for this i will work my way through it and report back.
Oct 17, 2025Guru - Experienced User
mike_wilson wrote:i have two RND2000-v2
Does the front panel say ReadyNAS Duo ? Or does it instead say ReadyNAS Duo v2 ?
The other labels are confusing, the front panel is the easiest way to tell exactly what you have.
mike_wilson wrote:i do not have the current password so i have to do a boot and default to factory settings
but after some time the power button continues to flash, and the activity led flashes
Actually it can be reset w/o losing data by doing an OS Reinstall. But your second step might have eliminated that possibility (sinc powering up while holding down the reset will start a factory default after about 25 seconds).
But we can give you more data once we are certain on the model details.
