mike_wilson
Oct 17, 2025Aspirant
RND2000-V2 cannot reset to select factory default
i have two RND2000-v2 that both are causing the same problem. Let me first say that i do not have the current password so i have to do a boot and default to factory settings. If i power up, with...
- Oct 23, 2025
thanks for this i will work my way through it and report back.
mike_wilson
Oct 24, 2025Aspirant
Stephen, you are absolutely spot on, i worked as if they are duo v1 and all went well. the firefox access worked as well.
i am so grateful for your help.
one thing i discovered was that the ip address and all programmed parameters follow the disk volume across machines. i think that also confused things when i was trying to debug the situation.
again many thanks
mike
- SandsharkOct 24, 2025Sensei
The IP address follows only if you've set a fixed IP in the NAS. That's usually not the best way to go. Reserving an IP in the router is usually preferred. That way, if you switch routers and the new one doesn't use the same subnet as the old, you don't lose access to the NAS.
