theman88
Feb 04, 2018Aspirant
RND2110-100NAS management
After not using my NAS for at least several years, I would like to get the steps for upgrading the firmware (if needed) or even just getting access to it from a Mac. I have tried to use the RaidAR 6...
Feb 04, 2018Guru - Experienced User
Are you able to find an IP address assigned to the NAS in your router's attached device list?
theman88
I actually "hardwired" the NAS' MAC address to a specific IP address. And, I have been able to start a TimeMachine backup on it. The question I have now is why Apple's TimeMachine says I only have 601 GB total capacity when it is a 1TB. Although I have some data on the drive from previous uses, I do not think it is taking up 302 GB of space. The readout on the management console for the space left is a little better but still 363 GB out of 925GB. How can I figure out where all this data is stored on my one hard drive? I am backing up a good amount of data over the network. But, TimeMachine says the entire backup will take 11 hours! Will this improve much if I am directly hardwired to my router? Also, I am debating whether I want to upgrade the drive to a 2TB or get a USB connected device like the 8TB WD my book drive. I know in some of your previous posts you have mentioned the Seagate "ironwolf" or the WD red drives. Is this still the recommended vendors ?
- StephenBFeb 04, 2018Guru - Experienced User
I'm not a mac user, so it's probably best for someone else to address the timemachine questions.
They are good choices for your NAS. Note the hardware compatibility list for your NAS hasn't been updated for years, so it really isn't a useful guide.
- theman88Feb 04, 2018Aspirant
Does anyone have any experience doubling the amount of space by using RAID-0? So, i am interested in making my NAS capacity 2 TB by buying a second 1TB drive to complement my 1TB drive. Does that require one to use FLEX-RAID instead of X-RAID? Or would my setup be supported by X-RAID?
- StephenBFeb 05, 2018Guru - Experienced User
You need to use flexraid, and with your NAS that requires a factory reset. Getting into flexraid also requires RAIDar 4.3.8 (the newer RAIDar 6 won't handle it). Since it is destructive, you'll need to back up your data and document your configuration (users, sharenames, etc). If you have any add-ons installed, you'll need to reinstall them - so you'll have to track down the .bin files.
The most robust way to use RAID-0 is to set up two volumes, one for each disk. My own duo is set up that way to maximize space. If you use RAID-0 to create a single 4 TB volume, then if you lose either disk you'll lose everything on the volume. If you have two volumes, then losing a disk only costs you the data on the that disk.
If you want to use 2 volumes, then I suggest doing the factory reset with only the new disk in place, and setting up flexraid. After that, hot-insert the old disk, and add it as a second volume. I find that's a bit more reliable (sometimes I've ended up in the wrong RAID mode when I've had both disks installed).
If you use Windows, I suggest considering upgrading to a new OS-6 NAS instead. Your old Duo is limited to SMB 1.0 (CIFS), which Microsoft is deprecating due to security issues. A new OS-6 NAS (an RN212 for example) is much faster, supports SMB 3, and also supports much larger disks.
