HughFrederick
Jul 31, 2019Aspirant
RND2110 factory reset > "device offline"
I can not get past device off line message on ReadyNAS control panel. successful factory reset apperred to happen overnight with: v 5.3.5 on rt column yellow icon on RT
Jul 31, 2019Guru - Experienced User
What model NAS is this? The RND2110 doesn't have an LCD control panel.
- HughFrederickJul 31, 2019Aspirant
I shoud have said ReadyNAS Dashboard
the "device offline" message is a popup dialog
HughFrederick wrote:I shoud have said ReadyNAS Dashboard
- StephenBAug 01, 2019Guru - Experienced User
But you are reaching the ReadyNAS web ui?
Or do you really mean RAIDar?
- HughFrederickAug 01, 2019Aspirant
Yes RAIDar 4.3.8 recognises NAS and displays blank dashboard with very little data other than drive capacity.
Netgear RAIDar 6.5
yeilds dialog box that hang forever.
don't know how NAS couldn't be on different sub net
assume Drive wouldn't even show up if cable was bad.
