glwrnsn
Jun 20, 2016Aspirant
RND4000-100NAS won't reset
Won't reset at all, have pushed the button numerous times, its dead. Tried the online reset, but the link is dead, it goes nowhere. Can't do setup in RAIDar, it won't recognize my password. Went into password recovery, and it won't work either. RAIDar sees the NAS, I can ping it, but Win 10 doesn't see it in the network, don't know why. Really frustrated.
What firmware are you running?
BTW if your part number is correct in the title, you have a v1, not a v2.
- glwrnsnAspirant
I am working with a win 10 OS. I don't know the firmware. I obviously don't know anything about these NAS, because I don't even know where to find it. The NAS came with a disc which contained RAIDar and NTI Shadow, nothing else. I have no dashboard that so many people speak about. What am I missing? Do you access this thing with DOS?
Interesting comment about the version because right on the label it says its v3. That all sounds so weird to me. Have I got a freak?
- BrianL2NETGEAR Employee Retired
Hi glwrnsn,
Welcome to the community!
Try to do the ff.
1. Download and install RAIDar in your PC.
2. Connect the ReadyNAS on your network via LAN.
3. Remove the disk and boot it up.
4. Open the RAIDar utility in your PC.
Check if the device shows up on the utility and tell us if it obtains an IP address from your network. Also, send us a PM together with the serial number of your unit.
Kind regards,
BrianL
NETGEAR Community Team
