ATG1
Aug 09, 2012Aspirant
RND4000, NV+ v1 -- RAM tests bad
ReadyNAS NV+ v1, 4 -WD 500GB Caviar drives, 256MB of memory. The NAS has been running for a number of years as a basic file server. More for storage as it was accessed rarely. One day it locked u...
PapaBear1
Aug 13, 2012Apprentice
First - Netgear ships 1GB memory modules with their x-86 based units which use DDR2 and DDR3 memory and the ARM based units which I believe use DDR3. The sparc based ReadyNAS units use DDR memory modules. Please make sure the slots in the modules are in the same place before you attempt to install it. The key slot is in different spots on DDR, DDR2 and DDR3 memory (both DIMM and SO-DIMM modules).
