ATG1
Aug 09, 2012Aspirant
RND4000, NV+ v1 -- RAM tests bad
ReadyNAS NV+ v1, 4 -WD 500GB Caviar drives, 256MB of memory. The NAS has been running for a number of years as a basic file server. More for storage as it was accessed rarely. One day it locked u...
PapaBear1
Aug 19, 2012Apprentice
Maybe. One of the reasons that Netgear no longer maintains a compatibility list for memory modules is the fact that the manufacturers change them without changing the model numbers.
The one I have that did work is a Micron 1GB DDR-333 CL 2.5. The model number on the top line is MT16VDDF 12864HY 335D2. Since it was purchased from HP, it also has the HP sticker with P/N 396330-632. It has 8 square memory chips in two rows of four on each side of the module.
Here is a link to the data sheet. http://datasheetz.com/data/Memory%20Cards,%20Modules/Modules/MT16VDDF12864HY-335D2-datasheetz.html. Since I bought this in 2006, they may be difficult to find. Others with the spec of DDR333 CL2.5 may work and they may not. If you try one, best to run the memory test several times. Apparently from past posts, your chances are better for success if the module has 8 chips per side rather than the later 4 chips per side.
