kturcotte
Apr 21, 2012Aspirant
RND4000 NV+ v2
I have a couple of questions before I purchase the RND4000 NV+ v2. Basically, I'd like to use it as a media server. I'd want to put 4 3TB Western Digital hard drives into it. I'd like it to run in 2 d...
angelia
Apr 27, 2012Aspirant
PapaBear wrote: Power consumption for the NV+ v2 is shown as 48.5 watts on the comparison chart with the note that it is with 4x1TB drives. The technical specs for the NV+ v2 shows 52W typical with 4x2TB drives. Both sound reasonable to me. The 2TB will take just a bit more power as there is probably some incremental additional disk weight to spin. The unit comes with a 90W external (brick) PSU. That does make it easy to change.
thx you tell me that, The 2TB will take just a bit more power as there is probably some incremental additional disk weight to spin. :slap:
