Junyar
May 07, 2018Aspirant
RND4000 SV1 Swap
Hello,
My ReadyNAS RND4000 NV+ has just died. I have managed to chance upon another new and never used RND4000NV+ to replace it. How do I go about swapping them over, is there a process I should fo...
- May 14, 2018Thanks for the help everyone. I followed both advice, booted with an old hard drive accessed the NAS via the web interface, downloaded the latest firmware and updated. I then put my hard drives back in order and rebooted. Rebooted in good time and could see my files. Took the NAS about 24 hours to file check and sync and I now have access to everything.
Now to clean up the files and think of a plan to make sure this does not happen again.
Thanks again for the help.
Marc_V
May 08, 2018NETGEAR Employee Retired
Hi Junyar
Welcome to the Community!
NV+ has V1 and V2 so you need to make sure they are the same. How to tell NV+ V1 from V2.
You can just plug in the disks in the same order as with the Old NV+ then turn on the unit. It should boot normally given that the disks are still healthy and you should be able to access your data back.
It's good to hear that you were still able to find a replacement unit. If you have purchased that Brand new from a NETGEAR Authorized reseller you can try to contact NETGEAR Support and register your device and provide the Proof of Purchase. You might be able to take advantage of the Warranty.
Regards
Junyar
May 08, 2018Aspirant
Thanks for the response and the link Marc. They are both the NV+ V1, so a straight swap and reboot should be all that is needed. Will I have to reconnect and rename etc.?
- StephenBMay 08, 2018Guru - Experienced User
Junyar wrote:
They are both the NV+ V1, so a straight swap and reboot should be all that is needed. Will I have to reconnect and rename etc.?If the firmware in the flash doesn't match the original NV+, then the replacement will install that version onto your disks. So it's best to set up the replacement with a scratch disk first, and then update the firmware if needed. That prevents the risks of a large downgrade causing issues (which could put your data at risk).
Once that is done, power down and migrate the disks (preserving slot order), and power up again. The settings are all on the disks, so there's no need to reconfigure anything.
- JunyarMay 08, 2018AspirantThanks. How do I set up a scratch disk? Also I am not sure what firmware was on the dead one. Can I check?
Junyar wrote:
Thanks. How do I set up a scratch disk?A scratch disk is just a SATA disk you happen to have that you are willing to use for this. It needs to be <= 2 TB in size, and it will be reformatted as part of the process - so any data on it will be lost. It doesn't need to be on the hardware compatibility list - it won't be in the system for long, and you won't be putting any of your data on it. It shouldn't be one of the disks in your old NAS.
Junyar wrote:
Also I am not sure what firmware was on the dead one. Can I check?If the NAS won't boot, then you can't easily tell the firmware. It is ok to use the current firmware (4.1.16) on the new NAS, as upgrading firmware doesn't carry the same risks as downgrading.
