Junyar
May 07, 2018Aspirant
RND4000 SV1 Swap
Hello,
My ReadyNAS RND4000 NV+ has just died. I have managed to chance upon another new and never used RND4000NV+ to replace it. How do I go about swapping them over, is there a process I should fo...
- May 14, 2018Thanks for the help everyone. I followed both advice, booted with an old hard drive accessed the NAS via the web interface, downloaded the latest firmware and updated. I then put my hard drives back in order and rebooted. Rebooted in good time and could see my files. Took the NAS about 24 hours to file check and sync and I now have access to everything.
Now to clean up the files and think of a plan to make sure this does not happen again.
Thanks again for the help.
Marc_V
May 14, 2018NETGEAR Employee Retired
Hi Junyar
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Junyar
May 14, 2018Aspirant
- StephenBMay 15, 2018Guru - Experienced User
The best approach is to put a backup plan in place.
Given the age of your NAS (the replacement has to be at least 7 years old), I suggest getting a new ReadyNAS model with new disks. You can then copy over the data from the NV+, and repurpose the NV+ (making it a backup NAS).
