Oz_Pete
Jun 24, 2022Aspirant
RND4000 trying to boot from USB but OS Index Error
Hi Team, I have an RND4000 NV+ 4 Bay. It is stuck on boot, I have done the initialisation of OS already, still the same. I have downloaded both the oldest and newest radiator bios firmware files fr...
Oz_Pete
Jun 30, 2022Aspirant
I have a spare drive now - its a Seagate Barracuda 160GB. I'll remove the data drives and number them. I will place the spare drive in a caddy and await instructions.
Many thanks in advance - Pete
Jun 30, 2022Guru - Experienced User
Just put the drive into slot 1, and then boot up the NAS and do a factory default. This normally will do a fresh factory install on the NAS. If that works (and the system boots normally), then the boot issue is actually due to something on the operational disks, and not the flash memory.
If you don't recall the factory default procedure, see pages 23-24 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
Note if the disk is unformatted, then the system will automatically do the install on power up (no need to use the boot menu in that case).
- Oz_PeteJul 12, 2022Aspirant
Hi Stephen,
I did get that disk and tried to run it up in the old chassis and it failed with a 'disk error - no disk'.
BUT I did get a hold of an identical chassis. I tried the same disk in that with the factory reset and it worked. I then put my original disks in the new chassis and it went thru an update of the firmware onto the disks, and then booted to the disks. I can see all my data in the original format so I have copied the data off, so at least that is done.
I tried first putting the new disk back in the old chassis and it hung on booting; then tried the original disks with the same result.
My take is the old chassis has some sort of 'boot' issue internally - be it the bios or something else.
Stephen what would you suggest from here?
Pete
- SandsharkJul 12, 2022Sensei
Your symptoms sound more like a power related issue. "No disks" with a drive inserted is typically a hardware problem, not a firmware one (assuming you know the drive is good), Replacement supplies are available, but IMHO it's not a worthwhile expense at this point due to the age of the NAS and since you've recovered your data. Not to mention I'm just guessing that would even fix the problem.
Totally agree Sandshark - if it means spending $$ / replacing parts then it's going to god.
- StephenBJul 12, 2022Guru - Experienced User
Pete
I agree with Sandshark that this is likely a power issue with the old chassis.
If the replacement is a chassis you can keep, then I suggest keeping the old one around. It's possible that something on the system board of the replacement will fail, and if so you can shift back to the old chassis (also moving the power supply from the replacement back to the old chassis).
If the replacement isn't yours to keep, then you should find a more current storage solution (and you might want to plan for that anyway, given that the Netgear stopped manufacturing your NAS about 10 years ago). Definitely shop around, I think it's increasingly clear that Netgear has silently left the NAS market, so you likely will need to switch to a different vendor.
