Zombie_Zoo
Apr 27, 2016Aspirant
RND4000 v3 not powering on
SN# 23J5127M00528 I powered it down to move it to another location and it does not power back on. It seemed to be working fine up to this.
- Apr 29, 2016
Then likely the PSU has failed. The hardware warranty is 5 years, so you could check to see if you are still covered. Even if you aren't, you can try contacting netgear support, and see if you can get another PSU.
A new NAS would deliver much higher performance than the NV+, so it is probably not worth a lot of investment (either time or money).
Do you have a backup of the data on the NAS? If not, Netgear support could help you migrate the data (if you buy a new ReadyNAS).
BrianL2
May 11, 2016NETGEAR Employee Retired
Hi Zombie_Zoo,
No worries. Take a quick look at this document before you take out and replace the PSU of your ReadyNAS unit.
Hoping for a positive result.
Kind regards,
BrianL
NETGEAR Community Team
May 12, 2016Guru - Experienced User
Also if you use a stock ATX supply, you will need to modify the pinout. You can do this with a 20 pin extension cable.
This pdf gives the pinout: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
