Jasooooo
Apr 27, 2011Aspirant
RNDP6000-200EUS vs RNDP6000-200NAS
Hi I'm getting confused - are the above basically the same model or are they different in some way? In the UK only the "RNDP6000-200EUS" seems to be generally available...I'm hoping that this is b...
mdgm-ntgr
May 02, 2011NETGEAR Employee Retired
The RNDP6000-100 was the Pro Business Edition. The 200 indicates the 2nd generation of the product. NetGear does it with there other products e.g. the GS108Tv2 switch is the GS108T-200.
The Ultra 6 Plus is the RNDP600U-200. Note the U in the name. It's also a second generation product as the first gen of this was the Pro Pioneer RNDP600E.
The 2 and 4-bay Ultras and Pros and the Ultra 6 (not Plus) are first gen products using Atom CPUs so they have -100 at the end of the model number, before the region identifier.
There's no problem mentioning the store you purchased your NAS from or where you're considering purchasing from. But if you say worked for or had some other interest in a reseller and went around spamming, by promoting it in lots of posts then that would be a problem.
