Jasooooo
Apr 27, 2011Aspirant
RNDP6000-200EUS vs RNDP6000-200NAS
Hi I'm getting confused - are the above basically the same model or are they different in some way? In the UK only the "RNDP6000-200EUS" seems to be generally available...I'm hoping that this is b...
vandermerwe
May 03, 2011Master
Of course you-dah is correct, however Netgear does control product information on their website. The information provided does not list a diskless Pro 6 unit on either the uk nor USA site. Netgear should also be concerned about customer satisfaction. The situation where 1 lesser product costs as much as a better product with longer warranty will lead to unhappy customers like myself, particularily when it was so difficult to be aware of the alternative,better product. The prices for the populated units are disproportionately high (3x1tb unit effectively adds 450 pounds for the disks. It's therefore only on these forums that I discovered the existence of the diskless unit, and too late. I can't return the ultra 6 plus without incurring a 15% restocking fee as I purchased it 4 weeks ago.
The store I'm looking at is Kikatek
