Jasooooo
Apr 27, 2011Aspirant
RNDP6000-200EUS vs RNDP6000-200NAS
Hi I'm getting confused - are the above basically the same model or are they different in some way? In the UK only the "RNDP6000-200EUS" seems to be generally available...I'm hoping that this is b...
starbuck_
Aug 01, 2011Aspirant
Hi,
I want to buy a new 6 Bay ReadyNas Unit from the new Readynas Pro Family to replace my old NV+.
Is the RNDP6000-200EUS the correct type for the new Pro6 Diskless Version (2nd Gen.) in Europe ? (not the old Pro Business Edition!)
I read in the forums that
"The Pro 6 has the 2.6Ghz E5300 CPU" is this correct?
Some online stores show this CPU specification 1 x Intel Core 2 Duo 2.8 GHz (Dual-Core).
I am a bit confused now which specification is correct.
I would appreciate it if some could shed some light on this matter.
Thank you.
Thank you.
