Jasooooo
Apr 27, 2011Aspirant
RNDP6000-200EUS vs RNDP6000-200NAS
Hi I'm getting confused - are the above basically the same model or are they different in some way? In the UK only the "RNDP6000-200EUS" seems to be generally available...I'm hoping that this is b...
mdgm-ntgr
Aug 01, 2011NETGEAR Employee Retired
Yes, the -200 indicates it's the second gen. I believe the CPU is the 2.6Ghz one, but it should be easy to check when you get your unit in the logs or via SSH (if you're comfortable with that)
