Jasooooo
Apr 27, 2011Aspirant
RNDP6000-200EUS vs RNDP6000-200NAS
Hi I'm getting confused - are the above basically the same model or are they different in some way? In the UK only the "RNDP6000-200EUS" seems to be generally available...I'm hoping that this is b...
mdgm-ntgr
Aug 15, 2011NETGEAR Employee Retired
NetDelta wrote:
Also, the CPU specs link has a comment that indicates that the info may not be 100% correct.
That list was written by one of our fellow users, not NetGear so he felt it was appropriate to mention that the list may not be 100% correct (I believe it is currently 100% correct and he does try to keep it up to date).
NetDelta wrote:
Why doesn't Netgear just post a verified list?
They can change components used in NAS units. For most users performance figures are going to be more important to see than the model number of the CPU that is included.
