slayer722
Jun 25, 2013Aspirant
RNRXTRAY1-10000S tray compatiblity
Hello, I want to know if the tray with this part number RNRXTRAY1-10000S is compatible with my Readynas Duo RND2000 (sparc). Thanks for your help
mdgm-ntgr
Jun 25, 2013NETGEAR Employee Retired
No. The trays for rackmount devices are not compatible with desktop devices.
You need the RNDTRAY1
What happened to your existing drive trays? Was a tray stuck and did it break when you removed it?
