slayer722
Jun 25, 2013Aspirant
RNRXTRAY1-10000S tray compatiblity
Hello, I want to know if the tray with this part number RNRXTRAY1-10000S is compatible with my Readynas Duo RND2000 (sparc). Thanks for your help
slayer722
Thanks for your quick reply,
My trays have the well know problem with the round button that get stuck, but that's not very important since i have found a great trick for that on the forum.
I want to buy an additional tray to perform supplementary backups on another hdd.
Best regards
Best regards
