slayer722
Jun 25, 2013Aspirant
RNRXTRAY1-10000S tray compatiblity
Hello, I want to know if the tray with this part number RNRXTRAY1-10000S is compatible with my Readynas Duo RND2000 (sparc). Thanks for your help
Jun 25, 2013Guru - Experienced User
Just wanted to point out that backing up by inserting a new hdd is generally not recommended here. One issue is that SATA connector on the drive is not built for repeated insertion.
Another issue is that if you pull / reinsert a drive in the raid array, the full system will resync every time. During the period, the system is not redundant.
