vitk
Aug 30, 2011Follower
routers compatible with readynas duo
Hello, what is the wireless router most compatible with readynas duo? With my old Linksys WRT54G I started getting network errors and disconnects (when copying large files over wireless) after putting...
PapaBear1
Aug 31, 2011Apprentice
I replaced my WRT54G router with a refurbished Netgear WNR2000 that I got off Newegg for $22. (Currently $39 with shipping). I also included in the system a Netgear GS108 switch since the router ports are only 100Mb/s (as are the ones on the WRT54G). This way, my wired PCs and the NAS units benefit from the gigabit speed of the switch. (Only my printers are directly connected to the router).
You might want to try a direct connection test to make sure it's the router, not something in the NAS. Of course, if you would benefit from a change from b/g to b/g/n then an upgrade would help. Unless you buy a new router that has gigabit ports (1000 Mb/s) rather than the fast ethernet (100 Mb/s) and you are using a wired PC, consider a gigabit switch in the network rather than changing the router.
