warobald
Aug 08, 2021Aspirant
RR2304 - shows offline (in readycloud app/web) - can't connect to Admin via ip address
Today I started to receive unable to connect errors with my network shares to shared folders on my ReadyNas. Both the readycloud web interface and the readycloud app on my PC (windows 10) show the de...
warobald
Aug 09, 2021Aspirant
Raidar can't find any NETGEAR storage on my network. The Health LED is not on. The network LED is blinking green.
Aug 09, 2021Guru - Experienced User
Did you try power-cyclng the NAS?
- warobaldAug 09, 2021Aspirant
Not yet - is there a specific procedure for this?
- StephenBAug 09, 2021Guru - Experienced User
See page 25 in your hardware manual: https://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS6_Rackmount_HWM_EN.pdf
The preferred shutdown might fail, given your symptoms.
You were right - the preferred shutdown didn't work - the forced shutdown did. Restarted and I can now access device via web and direct with IP address. Thanks for your help on this!
(I guess as a long-time windows user I should have known to power-on/power-off)
