cheajack77
Aug 01, 2020Aspirant
RR2304 "Shares" Missing In ReadyNAS Ver 6.10.3 Frontview Admin Page After Unexpected Power Failure
RR2304 (RR230400) "Shares" missing in ReadyNAS (Ver 6.10.3) Frontview Admin Shares Page after an Unexpected Power Failure. (Prior power failure, all "Shares" were there and normal) After the inci...
Aug 02, 2020Guru - Experienced User
This sounds like something has corrupted the NAS configuration files.
One option is to use paid Netgear support (per-incident support should be enough, and should cost less than $100 USD).
If you have ssh enabled, and are comfortable using it, there is a script you can run that can repair the config. Though you should also check for a full OS partition before you run it.
- cheajack77Aug 15, 2020Aspirant
Thanks for the workaround.
However, Netgear should resolve the inherent OS Frontview Shares bugs problem of Disconnected Shares, which I'm not the only one but many other cases happened already due to various problems.
Mine was coincidentally running normal without any upgrading or migration, except the only power interruption that assumed had caused the "Frontview OS's Shares corrupted/disconnected".
Please note that all my Data in the NAS are still there and after Full Data comparison check against other backup was NOT corrupted, EXCEPT Frontview's Shares Configuration integrity which not always changing seems corrupted, which I have no idea.
So Netgear should fix the Frontview OS problem to include its Shares self-check/rebuilt/system checks.
If the script could repair the configs, then should let the updated Netgear system firmware to have this option instead asking enduser to access SSH, which some enduser not even know how to do that.
In the meanwhile, I could only try study your solution if feasible. Please email me the script and method.
Thank you.
- StephenBAug 15, 2020Guru - Experienced User
cheajack77 wrote:
... However, Netgear should ...
That's not my call, as I don't work for them.
To be clear, it's not my script - and it's not something I've needed to run. The Netgear mods have sometimes suggested it (and provided the link), and it's resolved the problem in most (if not all) cases. I haven't seen any cases posted here where it has done more damage. But you of course are on your own if you choose to run it.
You can find it here
- SandsharkAug 15, 2020Sensei
I have looked at the script, and my conclusion is that running it for the wrong problem could cause more damage than good. It is also set up to provide feedback if it's seeing something unexpected, and getting that feedback out would be another challenge. Thus, I understand why it's not automatic or available for running without first interacting with support or the forum to insure it's the right fix. Building in the smarts to insure it's really the right fix and do so automatically would be quite an undertaking, especially for a failure that is very uncommon (it may seem more common if you look here in the forum only because people with no problems don't post that fact). I initially wondered why it was not available as an add-on instead of a shell script, so SSH is not necessary. But seeing the feedback messages that can be given, I now also understand that.
Your problem does sound like the script is the correct fix, however.
Since you do have access to your data, just not in the typical share organization, you should insure your backups are up to date before using the script in case your situation is one of those that can be made worse by it. If it does get made worse, you can then factory default and restore the data.
