petekoss
Dec 07, 2017Follower
RR331200 Diskless Startup Procedure
Just received a diskless RR331200 with Firmware 6.5.1 and the unit just flashes its blu LED power light. I have inserted two unformatted, Netgear approved HD's into slots 1 and 2. The unit has been...
mdgm-ntgr
Dec 07, 2017NETGEAR Employee Retired
It should automatically do a factory reset when you power on with only blank, unformatted disks installed.
If you inserted the disks after power on, reboot the system.
If that doesn’t resolve it check if you can see it in RAIDar and if there’s an option to erase used disks using that.
If that doesn’t resolve it can you hook the disks up to a PC and delete any partitions off them.
Another option would be to try the factory default boot menu option. As your system is on 6.5.1 you’ll need to use the serial console as described at the bottom of the article.
