olest
May 20, 2020Guide
Rsync timeout RN316 6.10.3
After some of the later firmware updates I started getting timeout errors when doing rsync backup from my readynas to remote NAS (Synology). rsync: [sender] write error: Connection reset by peer ...
May 21, 2020Guru - Experienced User
Do you see the same error if you run rsync on the Synology instead of as a ReadyNAS backup job?
Anything change on the synology over this timeframe?
olest wrote:
I see nowhere to set rsync timeout value.
There isn't a setting exposed for it. But a connection reset isn't the same as a timeout. Generally the reset error means the connection has actually been broken.
Are the two NAS on the same network?
- olestMay 21, 2020Guide
I havn't tried to run the job reverse from the Synology.
The backup is done over a 100Mbit IPSEC VPN connection.
Tried to ping from the Readynas to the Synology while doing rsync from Readynas and I get 0% packet loss (0 packets lost) but the backup still fails.
