olest
May 20, 2020Guide
Rsync timeout RN316 6.10.3
After some of the later firmware updates I started getting timeout errors when doing rsync backup from my readynas to remote NAS (Synology). rsync: [sender] write error: Connection reset by peer ...
olest
May 21, 2020Guide
I havn't tried to run the job reverse from the Synology.
The backup is done over a 100Mbit IPSEC VPN connection.
Tried to ping from the Readynas to the Synology while doing rsync from Readynas and I get 0% packet loss (0 packets lost) but the backup still fails.
May 21, 2020Guru - Experienced User
I'd look at the full logs on both systems, and also try running the rsync on the synology and see if it behaves the same way.
- olestMay 21, 2020Guide
The Synology does not support backup FROM a rsync server.
Where do I find the logs?
- StephenBMay 21, 2020Guru - Experienced User
I think you could run it using ssh. This is intended as a test.
Download the log zip file from the logs page.
- olestMay 26, 2020Guide
Trying to do rsync the reverse way from Synology using Synology Active Backup for Business - I'll update with the result later.
Does Readynas Rsync use BLOCK LEVEL transfer for each file or does it transfer the whole file if it has changed?
