Jelle
Jul 25, 2011Aspirant
SATA 600 in Netgear ReadyNAS NV+ RND4000
Hi, Is it possible to use SATA III disks in the Netgear ReadyNAS NV+ RND4000? For example the Barracuda Green 5900.3. I understand that the disk will only run at SATA II speed and performance,...
PapaBear1
Jul 25, 2011Apprentice
You mean like the 2xHitachi HDS5C3030ALA630 drives I have in my NVX? Yes. They do very well in fact. All SATA drives are backward compatible, the newest drives can even be used in the SATA1 interface found in the older ReadyNAS units.
In fact a look at the specs will show that even the original SATAI drives will saturate a gigabit network. A gigabit network will transmit data at 1000Gb/s while the SATAI drives will send that data at 1,500Gb/s. The data speed of the hard drives has never been the limiting factors. In my NV+ for example with SATA1 interface, it was the CPU while in the newer desktop x-86 machines it will either be the CPU or the NIC.
