THN
Dec 29, 2008Aspirant
Script to Connect to Network Drive
Good Day all, I've gleaned so much information from these posts, that I thought it's time for me to contribute something, as well. So, here we go: I have created a little vbscript, which can be...
lordoflard
Aug 17, 2009Aspirant
Just to add my two penn'orth...
If you're using a batch file like jamesd and you have a number of shares to map, you can issue the command:
Of course, if you don't want to include the user's password in a plaintext script, omit the "%NASpass%" and a password prompt will appear in the command window.
The Lord of Lard
net use \\%NASname% /user:%NASuser% "%NASpass%" /persistent:nothen each share is connected using something of the form:
net use Z: \\%NASname%\ShareNamewhich will save, ooh, a second or so of typing or copy & pasting. I've found this method of connecting as the user before attempting to map drives to be slightly more reliable in an office of mixed Windows versions.
The Lord of Lard
