thepup
May 01, 2012Aspirant
Seagate ST2000DL003 2TB with ReadyNAS Duo v2 ?
Hello, The Seagate ST2000DL003 Barracuda Green 3.5-inch 2TB SATA 6 Gb/s Drive (64MB Buffer,5900RPM) is listed on the HCL as compatible with the ReadyNAS Duo but is not listed for the ReadyNAS Duo v...
mdgm-ntgr
May 01, 2012NETGEAR Employee Retired
There is a known issue with this drive at the moment and there is a test drive firmware that should address it. I would not recommend this drive for any ReadyNAS model at this time. Perhaps look at the Hitachi drives on the compatibility list.
Can you provide a screenshot (you can use e.g. imageshack and paste the forum code here).
