thepup
May 01, 2012Aspirant
Seagate ST2000DL003 2TB with ReadyNAS Duo v2 ?
Hello, The Seagate ST2000DL003 Barracuda Green 3.5-inch 2TB SATA 6 Gb/s Drive (64MB Buffer,5900RPM) is listed on the HCL as compatible with the ReadyNAS Duo but is not listed for the ReadyNAS Duo v...
thepup
Thanks for your reply mdgm. I have a couple of questions :
1. What would you like me to provide a screenshot of ? I can show how Windows offers just 3.99GB on each share. I can show "volumes" being empty on the "system" tab. Or was there something specific you would like me to capture? Sorry if I have missed the point, but I'm not at all familiar with ReadyNAS.
2. Do you have any details of the test drive firmware that you mentioned ? Where can it be found and how is it installed ?
