thepup
May 01, 2012Aspirant
Seagate ST2000DL003 2TB with ReadyNAS Duo v2 ?
Hello, The Seagate ST2000DL003 Barracuda Green 3.5-inch 2TB SATA 6 Gb/s Drive (64MB Buffer,5900RPM) is listed on the HCL as compatible with the ReadyNAS Duo but is not listed for the ReadyNAS Duo v...
tyc
Hi,
I think we have the same issues here, we have 2 Seagate Pipeline HD ST2000VM002 2GB drive with ReadyNAS NV+v2.
We try to setup as X-RAID 2, but after that, we also see 3.99GB on media and backup share. 'System' tab also show no 'Volumes' as well.
I just notice this drive NOT appears on the HCL for the ReadyNAS NV+v2, is it mean they are not compatible? Will the test-drive firmware support that?
Also, we follow the instruction try to access to the boot menu, it only allow "Normal Boot", is it relate to the disk compatible issue?
Thanks.
Thanks.
