Negative_Nancy1's avatar
Aug 06, 2012
Seagate ST2000DM001 for ReadyNAS NV
This is a ReadyNAS NV, not the "+". Finding disks for it are becoming difficult. I want to put 2TB disks in, but their either out of stock or priced so high, it's out of my range. The HCL seems so out of date for this device. I would like to add the Seagate ST2000DM001, available at NewEgg for $110. It's not on the HCL for the NV, but on the NV+. Will this work for the NV? Can anyone recommend a good 2TB HDD?
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Most disks compatible with the NV+ (v1) should be compatible with the NV. Anyway the NV would most likely be long out of warranty.
ProSupport for Business
