filmbuff
May 23, 2012Aspirant
Seagate ST3000DM001
hi, all. does anyone have any idea if Netgear will be adding the Seagate ST3000DM001 to the approved HD list any time? or if some fearless owner has tried running these in their ReadyNAS? i pur...
May 24, 2012Guru - Experienced User
I find it puzzling that a disk that works for RAID on the NV+ v2 doesn't work with all platforms (setting aside the 2 TB threshold). Are the RAID controllers that different?
readysecure1985 wrote: Looking through the HCL I am seeing ST3000DM001 as compatible for the NV+v2. As it has already been put on the list for one device and not for others I am highly doubtful that it will show up on any other in the future.
It might be nice if one of the Jedi talked through what the disk qualification process looks like, and what kinds of things you all find that rule disks out. Obviously you wouldn't want to single out specific disks models - I am thinking something broader.
It would also be nice to know if the HCL has really shrunk, and if so what that means for ongoing support.
