ReadyNASinUK
May 16, 2015Aspirant
Seagate ST3000VN000 (3TB) in ReadyNAS Duo v2 (Edit: Duo V1)
I see from other posts that the Seagate NAS drives are on the HCL, though not for older products like the Duo v2. I have also noted that there is at least one 3TB disk on the HCL for the Duo v2. ......
vandermerwe
May 16, 2015Master
First check which version of the duo you have:
http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
What firmware is on the duo ?- we can determine the version from this too.
Do you have a backup?
