ReadyNASinUK
May 16, 2015Aspirant
Seagate ST3000VN000 (3TB) in ReadyNAS Duo v2 (Edit: Duo V1)
I see from other posts that the Seagate NAS drives are on the HCL, though not for older products like the Duo v2. I have also noted that there is at least one 3TB disk on the HCL for the Duo v2. ......
May 16, 2015Guru - Experienced User
If you purchased around the time you joined the forum, then you have a duo v1. That is also consistent with your symptom (931 GB reported capacity on a 3 TB drive).
