ReadyNASinUK
May 16, 2015Aspirant
Seagate ST3000VN000 (3TB) in ReadyNAS Duo v2 (Edit: Duo V1)
I see from other posts that the Seagate NAS drives are on the HCL, though not for older products like the Duo v2. I have also noted that there is at least one 3TB disk on the HCL for the Duo v2. ......
ReadyNASinUK
May 19, 2015Aspirant
Thanks vandermerwe,
Your answer explains how X-Raid get the 4TB from 7TB of disk; obvious when you hear about it: to combine RAID-1 and RAID-5 to maximise data capacity - but very clever. If the 1TB is replaced by another 3TB, then I can see how - and I guess it will - X-RAID will convert everything into RAID-5 for 6GB data.
