nicho2016
Sep 09, 2016Aspirant
Seagate ST31500341AS-CC1H on ReadyNAS Pro Pioneer Edition(1YA59CRE00137)
I am running the above data storage with six drivers of Seagate ST2000DM001-1CH164. But one driver broken. Can I use one Seagate ST31500341AS-CC1H to replace the broken one? Thanks, Nicho
nicho2016
Thanks StephenB.
Can ST2000VN000 with any firmware be used on ReadyNAS Pro Pioneer Edition(1YA59CRE00137)?
Sep 09, 2016Guru - Experienced User
It should be fine (other folks have used in in OS 4.2 systems and it is on the HCL for the Pro Pioneer). The WD20EFRX certainly works (I'm a WD guy myself).
| Seagate | NAS HDD ST2000VN000 | 2 TB | 6Gb/s | 64 MB | Yes | 3 |
- nicho2016Sep 09, 2016Aspirant
Thanks for your explanation.
Can WD20EFRX work with ST2000DM001-1CH164? Your experience is very helpful for us.
- StephenBSep 09, 2016Guru - Experienced User
You can mix/match disks in a ReadyNAS, and both of these are on the HCL with no limitations.
I haven't used this particular combination myself, but I have mixed Seagate and Western Digital drives on my Pro-6 and had no problems.
Gradually moving to NAS-purposed drives as the DM's fail is a reasonable strategy.
BTW, RAID isn't enough to keep data safe, and I do suggest having an up-to-date backup before manipulating disks.
If the NAS is filling up, you can expand the volume by installing larger disks - XRAID will expand, but not contract. There are some limits to growth, in your case it depends on what disks you had in place when you did the original installation.
