Krowten
Dec 15, 2013Aspirant
Seagate ST32000644NS & ReadyNAS Pro 6
Hello, I have a ReadyNAS Pro 6 with 4 ST32000644NS 2TB drives. I'd like to fully populate my ReadyNAS, but these drives are no longer current. The hardware compatibility list only lists two Seagate...
mdgm-ntgr
Dec 15, 2013NETGEAR Employee Retired
If you use drives outside the compatibility list and run into issues support won't be able to help.
Having said that if you maintain an up to date backup (as you should anyway) the risk of a disaster is pretty low.
