vpoon87
Dec 16, 2015Follower
Seagate ST8000NE0001 Disks for ReadyNAS 3138
Hi all, Will these disks work for the ReadyNAS 3138? The 6TB ST6000VN0001 model has the "This disk should be compatible based on the test result of another disk in the same series from the disk m...
mdgm-ntgr
Dec 16, 2015NETGEAR Employee Retired
Provided it fits in the tray I think it should but YMMV. We don't have any 8TB disks on the list and it is possible there may be compatibility issues. There are support implications if you use disks outside the compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641
