saintalfonzo
Mar 20, 2020Guide
Selecting a UPS for my ReadyNAS 214
Hello Community,
I have just set up my ReadyNAS 214 and am quite happy with it. Since it is serving as an important backup destination, I want to protect it with a UPS. I can't find any guidelines on what types of UPS are supported. For simplicity's sake, I was wanting to simply connect my ReadyNAS to a UPS via USB. Reading the documentation for ReadyNAS OS6 it says I can connect via USB but gives no additional deatils on how to set up a UPS via USB as it does for SNMP or Remote connections.
Does it "just work" when I connect via USB or do I need to keep anything in mind to make sure the UPS I find is compatible with my ReadyNAS?
Thanks for your input!
If you choose a compatibnle UPS, it does "just work". The ReadyNAS uses Network UPS Tools (NUT) for UPS support. Their compaibility list is here: https://networkupstools.org/stable-hcl.html
- SandsharkSensei
Thanks for the quick response, Sandshark and for pointing me to the NUT documentation. I plan to order a APC Back UPS Pro and will post back my experience should that be useful to others also looking for a UPS solution.
For anyone else looking for a small UPS to work with your ReadyNAS 214, I just set up a new APC Back-UPS Pro 550 (BR550GI) and it works just fine, with ReadyNAS detecting it automatically without a problem.
